How do I turn on LED Flash for Alerts on the S3?
php111
Hey everyone,
Someone had on their iPhone turned on LED Flash for Alerts. I don't see it on my S3 even looking under Accessibility, but I looked on my old iPhone 4 which I don't use anymore and its deactivated to see what they are talking about, and I seen it, but I left it off on my iPhone because I never use the phone anymore since I upgraded to my S3. So, how do I turn on this LED Flash for Alerts on my S3? Or its not possibly on the S3?
I appreciate any help, and thank you!
Do you mean the camera flash LED at the back or the coloured LED at the front?
Both can be controlled with Light Flow app
I don't know how they have it set, but I believe and please correct me when a text comes in then the LED light in the back will flash?
Also, what free app would you suggest to turn it on and how do I turn it on using a free app?
The free version of Light Flow will do it but its notifications (alerts) are limited to a few apps (sms, gmail, etc)
Try the free one first if you have a US phone ;)
So, I won't be able to use it 24/7 if I want? I know the iphone could and its not limited. Are there any other free options that won't be limited?
The free version of Light Flow isnt limited by time mate its just limited in the apps it can handle notifications for.
Theres other LED notification apps but i dont know if they can control the camera flash and LF is probably the most respected. The Dev is a really good guy :thumbup:
Thank you!
I should probably add for anyone else reading, LightFlow uses about 1% of my battery as like a constant average.
My tip is, the main power use is caused by the app having to wake the phone to make it flash/change colour. The next biggest use is powering the LED. i set my LED colours to be very dark shades of that colour so it uses less power and also looks sexy. And i set it so that the LED stays constantly lit for a notification. Might sound daft but a constant dark colour is more efficient than a blinking one
OP was talkin about the camera flash i think mate. Ive only used that feature on LF to see if it works lol. i think it would use up a LOT of juice if you had it flashing in your pocket. As far as i know, the camera flash is just a very high current white LED :)
Question about the Light Flow app, can you use this to change your notification light from the blue to either the red or green? The red and green are brighter and easier to see from a distance.
Yeah you can change the LED to evry possible colour using a light grid on LF :)
S3 has red,green and blue LED in the notification LED so it can make any colour by mixing them at different levels
