How do I uninstall/delete a stock ROM from my Nexus 5
A
Android Question
Guest
I have a Google Play edition Nexus 5 with cwm and cyanogenmod 11 installed. I only bought the 16gb version and I want to delete the stock ROM that is taking up most of the space. As you know, you are unable to insert an SD Card anywhere in the phone so that can not be an option. PLEASE HELP!!
You can't delete the stock ROM--if you've installed CyanogenMod, then you have already replaced the stock ROM--it's no longer there since CM11 is there instead.
And yes, there is no external SD card for the Nexus 5...it's all internal to the device, although there will be a portion that is designated as the "SD card" but is actually allocated from the the internal memory.
Hope that helps!
Upvote 0
Hope that helps!
Then how can I possibly clear up my storage. I only have 1.17gb apps, 110mbmb, 1.27gb audio, 195MB downloads, 4.78mb cached data, 416mb misc. That can't possibly be 16gb
Upvote 0
Hi
Is there a nandroid backup of the stock rom there? It would be a really big dated folder I think. If so you should back it up to a pc before deleting it. (A nandroid backup is like a image of the entire phone which allows the phone to be restored to its previous state. It should have been made before cyanogenmod was flashed to the phone.
Install an app called diskusage which gives a graphical view of memory use - its good for spotting big files.
Roger
  • Like
Reactions: scary alien
Upvote 0
Hi
Roger
I did make a backup of the phone before cyanogenmod. But I don't recall putting the nandroid backup on my PC. The only other place it could be is the phone correct?
Upvote 0
Hi
It is always created on the phone or sd card and has to be moved to be of use if you have no sd card otherwise it may well be stuck on a phone that won't boot - the reason for having it! So yes, it may be in your phone storage.
Have a look with the app I mentioned - it show's system folders as well and big files are easy to spot.
Roger
  • Like
Upvote 0
Hi
Roger
What would it be called?
Upvote 0
The app or the location of the Nandroid backup?
I also cannot even find a folder by the name of nandroid. Even under the folder clockworkmod since that's the custom recovery I have. Please help fast!
I don't own an N5 (yet--it's been ordered) but you should be able to find it with a rooted file explorer (Root Explorer, ES File Explorer in root mode, etc.). I don't believe you can find it without having root or at least I can't see my CWM backup son my N7 without a root browser or exploring the filesystem via and adb shell.
The important point is that CWM should know where your Nandroid backup is...try booting back into recovery and seeing if the backup in question is present (you might want to save your current setup if you have enough space--although that seems to be the root of your issue, no?).
Sorry for not responding earlier but I'm not seeing post/thread notifications for the Guest Questions area.
Best of luck!
Upvote 0
BEST TECH IN 2023
Smartphones
