I have installed Evernote. It is not what I'm looking for. How can I get rid of it. Note3 Neo.
The only options in the App store are 'open' and 'update'.
Thanks, but it only pretends to uninstall. The program is still on my phone, and the App store page changes to Open and Update again.
This is a very determined PUP (potentially unwanted program) !
Thanks DC
Only thing is, it isn't there!
It is in a folder called Galaxy Plus. Which doesn't show up in the App Manager either
Maybe it belongs on the phone? And can't be deleted?
It won't uninstall for you unless you do as someone else has advised & root your phone. You don't really need to uninstall it as it doesn't cause any problems, and it isn't a PUP (Potentially Unwanted Program), as alot of pre-installed programs are forbidden from being installed or are given system application status so that you can't do it unless you root the phone, which gives you system privileges.
Sorry I disagree it is a PUP if I don't want it on my phone which I don't I should be able to just un-install it without having to root my phone. I have a Samsung note 4 and it came pre installed and without rooting there is no way to un-install hiding or freezing still brings up messages that it needs updates . all right it doesn't do any harm but it is annoying .and I don't want it on my phone so unless I root my phone which I don't want to do I can't remove it therefore like flicker it is a pup.I would definitely agree that it isn't a PUP, it really isn't doing anything harmful to your device or annoying, perhaps the worst thing would be that it occasionally automatically updates without the consent of the user, if you have that option enabled.
