How do I update Eset Nod32 antivirus offline?
You can update the product version by uninstalling your current version and then downloading the latest version from eset.com/download. If you currently have version 5 installed, you can check for the latest build from the program window.
If you're asking about updates to the virus signature database and/or module updates, you have to be online to download these updates. There's no URL for this update because the update downloads directly from our servers to your program installation.
