"Clipper" is another good one. It can show the current clipboard contents in the Notification dropdown and keeps a history where you can retrieve older items. You can "pin" items in the history to make them permanently available at the top of the list.
go to s note tap on a note,tap on icon that looks like page with pencil and tap on icon that looks like mountains,then tap menu key and a list comes up,one of which is clipboard.
Should be easier than that though
Out of curiosity have you had a different phone in which accessing the clipboard was easier?
