Accessories how do you charge? additional / replacement ... charger .. USB 3.0
InGearX
has anyone been able to find a replacement/additional charger ..
and Note 3 has fast charging
for that we need appropriate wall charger AND the USB 3.0 cable?
I have tried a few and all charge it very very slowly ..
OEM is like $40
anything cheaper?
all the other chargers I tried - charge 3x longer!!
I bought an Accellorize USB Folding Wall charger @ Walmart for $9.99. 5V 2.1A, let my Note 3 drain to 10% battery, then I started to charge. 90 minutes later I was at 100%.
You don't need a USB 3 cable to charge - only a mini USB. I use a standard wall charger as well as a car charger that I have for my Blackberry (uck - work issue) and it works just fine. Charges at a good rate.
The phone charges fast anyways. Just use the stock charger. you can get them cheap.
I find good microUSB cables feel a lot more stable/secure in the phone than the Samsung USB 3.0 cable, which always feels a bit... loose/with a lot of jiggle.
Probably why they didn't use it on the Note 4.
