How do you Clear play books samples?
Hi. I sampled some books which I do not want yet I cannot clear them from my lists? Can anyone advise how to clear them from the play books lists?
Cheers
Working from memory here, so, I hope this is accurate. Long press on the title you want to remove. A box should pop up that will enable you to delete or remove the title.
Hope this works for you.
I don't really use Google books, but I might try wiping the book apps data from your application settings in the main settings menu
You may lose progress on other books though, so I'm not sure how helpful that may be
