I installed a screen lock program on my DroidX. It is named "Screen Off FX" which one of those widgets that you touch and it has the same effect as a short press on the power button -- turns off the screen and locks the phone. During installation it asked to enable "force lock". I agreed since it seems to require it to work. Now I want to uninstall the app but force lock has to be disabled in order to uninstall it (according to the description in the market). The uninstall fails, apparently because I have not disabled force lock.
Problem is, I can't find anything in the DX settings to disable "force lock". Does anyone know how to do this?
