How do you arange widgets on Revolution. Remove and put what you want on a page and how to set up home page with just the widgets you want there. Can anyone help?
The same as any other Android phone. Long-press the widget until it changes color and (while still holding your finger on it) move it to where you want it on the screen and release. To delete it, move it to the trash can that will appear at the bottom of the screen once you've long-pressed it. To add a widget to a screen, long press an open spot on the screen until the "Add to Screen" dialog comes up, choose "Widget" and then select the one you want from the list. You can similarly add shortcuts to applications by choosing "Application" instead from the dialog and then finding the app you want. - MarkC
