how can an android OS be reset to factory default if it crash ?
Recovering to stock is called SBF when working with roms etc, check it out!
When you "brick" your phone, you can almost always unbrick it, I have done it MULTIPLE times and have brought it back to working just like before.
if this helps, dont forget the thanks button!
what do you mean working with roms? I am not familiar with this term.
I think you are correct, and if he isn't rooting, about the only problem that couldn't be fixed by this method would be side loading an app with malware.I think he mean't how to reset the phone, like we do in outs PCs when Windows freezes.
You can eitehr remove the battery, or press and hold HOME + POWER buttons for like 5 seconds, and it reboots.
You choose...
) he gets to the rooting and loading roms, he will have plenty of resources and probably the skill to fix just about anything. Especially on a Nexus as you don't have to circumvent road blocks (i.e. loacked bootloaders).
