huffman6977
i did the ota, but i want to try to root. i heard that i have to get .5 i found the link but what do i need to do once i download it?
You make sure you have sync installed on your PC and that it installs the correct drivers then you run the RUU program with the phone plugged in via USB.
I have the same question... I am not new to computers, programming, etc., but I haven't done much in a LONG time and this is my first smartphone ever.
what is "sync" and where do I get it?
Also, I understand I will loose everything when I go from .6 to .5... basically I will have an out of the box hero with the .5 update, correct?
PS - sorry I'm an idiot... just don't want to screw anything up, and want to make sure I know exactly what I am doing before rooting and flashing a ROM.
