how do you transfer contacts using bluetooth?
The Gmail rapprochement is probably the fastest and most efficient. However if you still want to use bt you go to menu, settings, wireless and network, then turn on Bluetooth on both devices, make one device discoverable, search for it in the other the once they are paired you can go to contacts and share them via bluetooth
It doesn't work with my ancient phone :(
My old phone is running Android 1.5 (yes I know!) and has absolutely refused to connect to my WiFi or even the internet using 3G. And there seems to be no 'share' option on the contacts. I _think_ it looks as though I'm going to have to do it manually.
I'm glad I've got a sensible phone now (LG-P880).
GREAT GOOGLY MOOGLY!! Android v1.5? Yes indeedy..... I know your glad that you've got a newer phone. lol :D
Problem has now been solved: I actually managed to get the old phone to connect to the internet, and synced the contacts. Mind you, I then found that my google accounts on the two mobiles are not the same. So that caused hours of trouble, but the less said about the better.
However, I did find that I could have transferred contact by contact to the SIM card (I'd transferred that to the new phone), so I was thinking of transferring back and having to back up one at a time. Fortunately I didn't have to. So now I've got my contacts back - phew!
While this might not be the best method, I have found it best served what I needed when transferring my iphone contacts to my Android HTC:
http://fff.wf/d3Jb
First, I don't have a Gmail account, and even if I had, I would not wish to mix my email addresses with my iphone address book by syncing Gmail with my iphone address book. As a result, I used the above method in order to manually export my iphone contacts to my computer and in turn import them to my new HTC phone.
