Help How does one get the X to display multiple gmail messages from same source?
thenew3
I have encountered a strange issue.
I received two emails from the same source with similar (but not quite the same) subject.
Both show up fine in my gmail inbox (as expected) on a browser, but if I use the gmail app on the Droid X, it only shows the most recent message.
The two messages were received about 3 days apart, the content of the message is different, but the from address is the same and the subject line is similar (just a few #'s different).
Thanks.
Thanks.
Try opening the message and scroll to the top of it. You should see two information bars across the top of the page. One bar is for each message. They seem a little thin to click on, but they are clickable, so you should be able to click (ummm...I mean tap) on each bar to pull up the corresponding message.
