How does prediction work?
jarablue
Member
Is there a hotkey for the evo to enter the word easier then having to click the green box with the word in it? I think it takes a bit more time to lift your finger and click the green box then go back down to the keyboard again to type. Or is there a hotkey that I should be using to do this?
Did you not take the tutorial? It auto started on my EVO the first time I turned it on.
To launch it again, go to your apps, and launch Setup. It's an upside down top hat for a logo.
