Help How does this Gmote thing work?
JnEricsonx
I haven't downloaded it yet, but I've been told that it'll let me stream movies from my computer to my Tbolt? Which is good, because the room with the computer doesn't have 2 fans and a AC, whereas my bedroom does, so I'm sure I'll spend chunks of time watching movies in there. So, basically I shlep a bunch of movies into a directory on said computer, and....how does it go from there, before I download anything?
You'll want to install the server, which you can get from Gmote > server. When you configure the server it will ask which directories you want to share. Afterwards, launch the client on your Android device. If your accessing the server from a local network there should be a search feature that will scan for any gmote servers on the network.
I used it a while ago to stream my music catalog over 3G, for the lulz and all.
Good luck.
How the heck do you exit the program? I'm running it on a Samsung Charge and can't figure out how to CLOSE the program.
Very powerful and cool but very limited. Can I make a playlist or add songs to queue? I don't see the option for that. Would work sweet for pool parties at my house but without the ability to make the playlist, quite useless other than playing a specific song I have on my server.
