HoldFastHope
Member
I am coming up on my 30 day return deadline and want to see if my phone might have a hardware problem (hoping it doesn't) or if it's normal that i've got temps of up to 118 degrees. While idle or sleeping, the temp is of course low but once I start to fiddle with the phone, I see the temp go up and up quickly. Right now it's at 104.4F after about 5-10 minutes on my phone (web browsing, downloading apps, etc.) It is usually between 100F and 110F and sometimes the kickstand is hot to the touch. I feel like it gets abnormally hot in a short amount of time. Hottest it ever got was about 118F while playing home run battle 3D and my LED alternated which meant it was overheating. There isn't a day that the phone does not get hot. Also, I do have a case on it which might contribute to the heat a bit.
What are your normal temps while using the phone?
Please try to note the amount of time you were on it and what apps were being used. Thanks.
