Dankees
I recently had my phone replaced because it was overheating (over 120 degrees), and the screen was also messing up, etc. Anyway, I got the phone replaced and I have found that the phone is getting hot. It is typically above 100 degrees during the day. I have found that it gets hotter while not connected to Wi-Fi, and it gets hot while connected to the charger. But, even at home, while connected to Wi-Fi, it still gets hot.
Could my battery possibly be the cause or should the phone typically be hotter than 100 degrees?
I can take my wife's battery and put it in my phone to see what happens, but I am curious to know what a typical battery temperature should be.
I have also found that my battery is draining more than I would like.
