Pinmac1
I was getting fed up of constantly hovering near the memory limit at around 21 Mb. I had thought of hanging on until Gingerbread but it had got a lot worse lately and I decided to factory reset and reinstall. Just before I did, I had a look under Settings>Applications>Manage Applications and looked at all my downloaded programs. I have Apps2SD installed so most programs are on the SD card with only a small part in the phone memory.
There seemed to be some programs with a lot of data so I ordered them by size and went through methodically deleting data that I thought was safe to delete. There were some I was amazed were so big. The worst culprit was Miren Browser which had 9mb of data. When I deleted it, it did reset completely and lost all my favorites but I reset them easily. When I re-opened Miren it asked if I wanted to clear data on exit which I ticked.
After I'd finished I'd gone from 21 Mb to 38Mb which is way more comfortable and lets me wait until Gingerbread is out before I decide whether it's worth factory resetting.
I was surprised that so many of the apps had so much data as I run Quick Cache Cleaner several times a day and I had thought that this would have deleted any unnecessary data.
I hope this helps somebody else with memory issues.
