I knew certain apps called GPS (Facebook, Google, etc.) but didn't realize that actually called up Maps as a process in doing so, although I guess that would make sense! I was thinking maybe it was my weather widget and/or live wallpaper but I guess it's just the gps initialization when I open certain apps...
I use all of those programs and my gps is never enabled unless I'm using it. what is the benefit to keeping your gps on all the time?
Not having to turn it on and off all the time? There's no point, imo, in turning GPS off since it's ONLY on and active when you use a gps activating app like Maps or Facebook. Once you exit those apps, gps is no longer active, even if it is on.
What is the benefit of turning it off? It's not using power unless something is using it.
Every time you turn it on, it will instantly try to get a fix, regardless of whether you want it to, so simply turning it on for 1 minute and leaving it off for 7:59 could use more power than leaving it on but dormant for 8 hours.
Also, since i use GPS to track my phone if it's lost, it being off wouldn't particularly be helpful.
I've been following this (and other) battery related threads since I got my SG3. The first advice I picked up was to install Juice Defender, and it helped a LOT. The next thing I did was turn off all sync-ing. Definite improvement. Yesterday, I turned on my location services to allow my weather widget to update...bad idea. Immediately I noticed significant drain increase. It's back off today and my battery is draining much slower. What strikes me as odd is Location Services or anything like it wasn't showing up on my battery monitor, but there's no denying it was the culprit. It's apparently being under-reported.
