I have the Samsung Galaxy Nexus and the reception is crappy at best. So, how is it on the Note 2? Would like a bigger screen, but don't won't the sorry radio trap again from Samsung.
\My reception is great but with any phone, there are variables to consider. And my reception being awesome doesn't necessarily mean you'll feel the same way.
I don't know who you're carrier is but you have enough time to decide if it works for you in the area you live, work or play. If it doesn't, return it.
It doesn't usually take 14 days to know whether or not your reception is good or bad.
reception is better than numerous phones I've owned, and roughly (prolly slightly better) the same as my Bionic.
I've been with Sprint for 12 yrs and I haven't had a phone with bad reception. If anything, reception was an issue in places were towers were non existent; but that's not the phone fault.
I'm finding the Note2 to be much better than the S3.I went from a Gnex to a Razr Maxx, Gnex had horrible reception where Motorola has always been excellent. I had the S3 and the battery life was much better than the Gnex and had much better reception. Still probably not as good as Motorola but very good. The Note 2 is comparable to the S3 if not a little better.
In Southeast Florida the reception via AT&T is really good, along with the LTE strength. I haven't tried the western area yet near 441 (State Road 7) but I will soon.
Why don't you all say where you are located so your reception has meaning?
