How Long Does it Take to Charge Your Note 3?
cyberrico
Member
I never timed it but from dead or nearly dead it takes me hours. More than 3. Possibly 5. I can live with it. I just charge it every night or every other night because the battery is so amazing and it's done when I wake up.
But should I be concerned that it takes so long? Yes I am using the good cable that came with my device.
With the charger and usb 3 cable that came with mine, it is about an hour from >15% to full on mine. Another charger and usb2 cable, about 30-45 minutes longer.
The trick is to not let it get to low before charging. I usually try to charge before discharging below 50 percent. Takes about a half hour to get back to 100 percent
I'd say about 3 hours or so to charge. Although I've had mine for a year and it only seems to get 4-5 hours screen on time now, as opposed to 6-7 when I first bought it. Maybe it's all the notification heavy apps that I have.
from 10%.. I think it is about 2.5 hrs on the phone
I have 2 spare batteries.. that I charge separately.. a very slow charger. it takes over 8 hrs ea.
but slow charging is better for life time of battery. I just plug them in at night.
