Pinmac1
So I finally have my shiny new Note! I gather that I need to fully charge it before I turn it on for the first time so that all will hopefully be well if it then goes into an installation of ICS. When I plugged it in the battery icon showed up as about half full. Noe there is nothing showing on the screen 2 hours later. How long do I need for the initial charge and how will I know that it has charged? Following advice on here I will then do a factory reset once I have ICS installed OK.
Can't wait to get started but don't want to rush things and cause myself problems later.
