How Long to Charge Battery
My replacement Inc will be here on Tuesday. What is the recommended amount of time to charge the battery the first time? When I was talking to Tech Support when my first Inc was having problems he told me it was best to charge a full 24 hours the first time.
I don't know if I can wait 24 hours after receiving my Inc before checking it out!
Thanks! That's what I did the first time but wanted to make sure I was doing it correctly before I charged up my replacement Inc. Certainly do not want to do anything that will mess with my battery life:p
HTC says it should take 3 hours to fully charge...if you charge via USB then it will take considerably longer since this is a trickle charge.
the sticker on the charger mentions 4-5 hours depending on battery.
isn't 24 hours for batteries that are ni-cads from the 1980's? :)
yeah i just plugged it in and started using it haha. couldn't resist. i've definitely notice the battery getting better. have about 50% battery left at the end of today with medium use. that's plenty good for me with BT off, location and mobile network on, syncing on, auto brightness on. lookin good.
"When I first receive my phone do I need to charge the battery? closeYour phone ships with a partially charged battery so it
