well the process is pretty quick. unrevoked will reboot your phone into bootloader and then load the new recovery. if it is not doing that then you need to check your drivers.
i had problems getting the driver as well. follow the instructions to the letter and you will be good. once the drivers are good the process is sooo easy. i love windows7 but the drivers suck ass.
