Root how much space should i have?
weirdfate
i odened back to stock
installed cm7 beta4
ran the data to ext mod
and i have
total space 120mb
free space 89.74mb
is this normal?:confused:
thanks in advance
installed cm7 beta4
and i have
total space 120mb
free space 89.74mb
thanks in advance
Doesn't sound right to me. You should be seeing a LOT of free space. How big is your sd-ext?
Make sure you are on the latest version of CM7 and Hotfix 3. Follow the directions exactly. It works like a champ. I am showing never less than 700MB free with a 1 GB partition.
Hroark has a kernel for this that works with stock GB now too.
Good luck.
installed cm7 beta4
and i have
total space 120mb
free space 89.74mb
thanks in advance
i did a factory wipe of my phone and sd card more then once
that doesnt sound right at all...
my phones internal memory is 160mb total
free space is 83mb but thats including root explorer, titanium backup, wifi tether, and of course some games, and my phone is still faster then it ever was.
Good luck.
Which hroark kernel works with stock?
Hey skater,
I believe he is talking about the kernel hroark posted in the cm7 data to ext thread... #43
here is Kouma Kernel Gb with this MOD, I dont think Kouma will mind that I made it
KoumaKernelGBwithsd-extmod.zip
I'm actually testing that kernel right now, lol. But I was just trying to point out that the kouma kernel will not work with CM7 and that if he is running beta4 he has to have the beta4 kernel. Just trying to make sure that he's not trying to use CM7b3.5 kernel on bet4 and vise versa.
good point. I saw you bopping around the threads and I thought you would know of that new post by hroark. I am running it right now too with ctmod. I just like the fact that it's another app i don't have to install, its simple, and seems to work just fine on my class 10 card. I've been meaning to try other mods (yours included) but there is something about ctmod that just appeals to me.
I just used to tb pro to make a backup, clean dalvik, no issues so far. I have not tried to restore a backup... yet. wish i could help.
That's what I have is TB pro, I tried to use it as a system app, didn't work. Tried to reinstall from the Market and still getting FC's.
I got the odin with cwm in it
I have the stock sd card(2gb i believe)
Have not put any thing on this phone except titanium back up
with the cm7 beta4 and the data to sd mod
