Wifi and bluetooth died how much to get Motorola to fix?
My phone is a AT&T and I am in Canada so going to AT&T is not going to work.
Unfortunently the Bluetooth and Wifi radios are part of the motherboard, so they can't be removed and replaced independently (at least not without hardcore soldering).
See here Step 10 shows the layout of the chips and their functions.
Is it possible to replace that chip with the working one from the mainboard (broadcom 4329) ???? I have the same issue and i wanna repair my atrix... Thanx
I suppose you could replace it, in theory. You might be able to re-flow the board and replace it. Although I think a much simpler route, would be to get a board from a unit with a damaged screen, and just swap the entire board.
