Root How to *228 after root using WW Rom
jhug
Hello All:
I'm rooted running the WW Rom.
Tried to do a *228 this morning to update my roaming capabilities...and because there is no keypad shown when the call initiates, can't put in the "1" to activate or "2" to update.
Is there a away around this?
Also - should I bother doing option#1 - or is that not necessary, just the #2 to update roaming?
Thanks
Easiest thing is to hold down Menu touch key and it will force a keyboard to open. Then, go to the numbers and press 1 or 2!
Works like a charm!
Hello All:
Thanks
Try *22899 which doesn't require any other input.
I saw *22800 posted somewhere, not sure what it is though I've never used it.
Alternatively, you can just call your regular way, and hold the Menu softkey during the call. Your regular keyboard will come up, then you can just shift to the number view and type that way. I tried that and it works :D
EDIT: Oops, someone already mentioned that... I guess I should read before I post ;)
