How to add a folder to a home screen.. (solved)
SlickVick
I had a folder on my homescreen that i had filled with app shortcuts.. I had another full of contacts for quick access.. I accidentally deleted these folders and now i cannot figutre out, for the life of me, how to create a folder on one of the home screens.. Can anyone help? I am rooted, if that makes a difference..
Shit... Problem solved..
The only way to create a folder on the homescreens is to long press an icon, than drag and drop it directly onto another already existing icon... At this point, you can create and rename folders, add different widgets and app shortcuts, etc..
