Help how to add music
ashimashi
How do I add music in my Samsung Galaxy s2?
I tried google but I get like 20 different things and don't know which one works or not. A friend of mine said you need to use a special feature like itunes but for Android. But I don't think that is true because you can add and remove pictures without any software.
Anyways how do I add mp3 music on my phone please?
Thanks a lot in advance. :)
in your SD card or external SD card, create a folder called "Samsung"
in there create another one called "Music"
then copy all your MP3 files in that Music folder.
It will not matter if you create sub-folders within the music folder, as the media player will just pick them all up
u dont need any software, like mentioned above. however if u DO use itunes, u can use software like itunes agent (free) or isyncr (paid) to automatically sync ur music to ur phone
