jetguat
So must of us know how to take a screen snapshot with the N3. Though I am endless frustrated using the hand swipe technique as i inevitably to impact something within the application that I am trying to take a snapshot of. That said.
The clipboard has the snapshot and you can view it in the gallery. its saved as a .png file. But for some sites the file sizes are two large. What is the method used to reduce the files size. Either via compression, or changing to a new format that can be reduced in size. Is there some capability that is native to do that?
thanks
thanks
