G gmermel Well-Known Member Jul 30, 2012 #1 can this be adjusted? mine will go to sleep while I am reading a web page unless I scroll before the set time.
Podivin Android Expert Jul 30, 2012 #2 Go to settings > display > sleep, then select the one that pleases you the most.
G gmermel Well-Known Member Jul 30, 2012 #3 mhotovec said: Go to settings > display > sleep, then select the one that pleases you the most. Click to expand... I must be dyslectic. I swear that's where I was looking. Thanks....
