After installing a new rom, if you sign into Market, it will try to reinstall those apps. If you're using the free version of TIBU, this means you'll have to "OK", one more dialog for every app that's already installed.
When restoring from TIBU, you should restore just apps + app data, nothing in green or red since this can cause FC's if it's from an incompatible rom.
Passwords aren't always restored as a security measure (and if you had to reenter your pw, would that be a hardship?).
Create a backup in recovery. If you don't like a new rom, you can go back to it.
A recovery backup is a backup of everything as it was when you backed it up. As long as you don't sbf back to Froyo from Gingerbread, you should be fine.
You do need to take precautions tho (like TIBU).![]()
I did not udnerstand but i hope i will be able to
THanks
