how to calibrate
refurbished phone with 15hours on
3600mah battery from amazon
basix+es
what is the best proper way to calibrate, i noticed when i odin'ed phone and put battery in the extended was getting used faster than the regular.
basix+es
possible eBay battery??? I have some non original 1500mah batteries although they work they don't last anywhere near as long as the original battery
Sounds like the battery could be bad right out of the box, but to calibrate you need to be rooted with clockwork mod. The you turn you phone off charge it to 100% boot in to recovery mode after charging and wipe battery stats to let it recalibrate that battery,
If you have a warrenty on the battery contact the seller and ask them to honor it, I got a replacement for mine with out a headache
Thanks guys. Well this fone is refurbished frm the metro store and i bought an origional new one
I have the extended 3600mah battery and the origional samsung too
It just seems the phone glitches alot if i turn it on when chargin.. i can put it at 1% n when i reboot its like 65 ;(
Very weird phone
So heres the thing. When i got the new battery it was working so effecient it took like 15min to go from 100 to 99 and now it just counts down fast like a regular battery. I left the house 2hours ago and 98-62
all this happened after the first time i calibrated it
