Yep, it shows the same here. Also shows as A855 under portable devices. Make sure you have "usb debugging" enabled on the phone (menu>settings>applications>development) then try and install the driver.
Device manager, it labels it as G:\ I right click on it uninstall it then plug it back in and the computer auto reinstalls the drivers it has that it thinks is right.
