Help how to change font color
You will find better information about this at XDA. They are not noob friendly tho. Well some are but just be warned.
XDA is for finding answers, not asking noob questions.
google+"how do I...." is a better way to go then hoping your question gets seen.
If you want the developer way, check there.
If you just wanna change your color and be done with it, check out an app.
I mostly agree. There it's apps there also for this but most apps require other steps first. I do things like this manual so I don't have to take the other steps.
There is no option to change the font color on the phone. However, you can try downloading the third party from the Google Playstore....If you get then you're lucky enough or unlucky....
Sure there is. You just have to know how to dig through the frameware & which files to change.
If you know the solution then let us know so, that we could use it. And, it will be helpful for the ppl who want.
I did. You dig through the frameware to find the files you want to change & edit what you want.
If you can't figure out how then you my try using the kitchen from XDA.
