How did you get the latest radio? Did you get a new Evo that came that way? Did you just accept the latest OTA update (before rooting)? Did you update manually? If so to the latest one, was it with the combo update? Unless you updated the radio, wimax, and pri all manually, and forgot nv, you must have the latest nv. Unfortunately, I don't think anyone really knows how to actually check the version. That is the latest wimax radio, though. You should also verify that you have the latest PRI. But like I said, the only way to miss that would be if you updated the other things manually, one at a time and forgot it.
