Another way to clear your phone data is by using the phones buttons and basically doing a factory reset. This can be done by following the steps below. The first choice option is to do it through the menu, but if this is not available in some cases were your phone is frozen you can do it another way.
This does wipe all the data on the device, including contacts, apps, pictures and videos.
1. Turn the power off. If your HTC Desire is frozen, pull the battery out and reinsert it
2. Hold the Volume Down button
3. Press and release the Power button
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button
7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO If you selected YES, all data including third-party applications will be deleted from the HTC Desire. Once the wipe is complete, the phone will reboot to its factory fresh state.
