I Use a program called "Advanced Task Killer" that i got from the market
you can select what items will be killed and you can also select what apps will be ignored
very useful been using it for a while now
Hello,
Whenever i press the home key for 2-3 secs. i see the task manager which shows me 6 last apps running. How do I close them so they don't take up memory etc. ? Sometimes Wildfire gets slower.
Any quick tips etc. to make it silky smooth in running also ?
Thanks.
if you keep using the back button it will shut it down.
To break the back, back, back, back chain in the browser use the menu button, Windows... to open a new window (press + in the top corner), then Menu, windows again and find the page you want to close and close it with the X in the other top corner.
in opera, I thought there was a mobile view setting?
Also Opera compresses the data so should be quicker than other browsers.
It is awful though[/QUOTE
Opera mini wont work on my wildfire, it will only open the odd simple page, other where i need to sign in, i enter the username and the password, hit enter and i just keep trying to load but doesnt go anywhere.
I had BOLT BROWSER on my nokia and its a fantastic mobile browser but sadly not available for android
