Tinkerman61
I just switched from a Blackberry to the Atrix.
- How do I select text then copy and paste it somewhere else?
Thanks!
Thanks!
It's easy to miss this feature. But in most menu/screen selections, you simply tap twice to highlight the text, press and hold a few seconds and a popup menu appears with the option to cut or copy the text. Then when you're in the text field you want to paste (like a text or email message), just press and hold in that field and you get the option to paste.I just switched from a Blackberry to the Atrix.
Thanks!
Thanks!
You don't have to use the Menu button, just press and hold on the text you want to copy and a selection box pops up where you can drag selection pointers. It's very easy and similar to the iPhone.In the web browser, click the settings/menu button, then click 'More', then look for 'Select text'. Paint the text you want selected, and when you're done, it will be copied to the clipboard. (This is something the iPhone really does a lot better than Android right now, unfortunately.)
Thanks, but that does not work.
I am trying to copy some text from one email to place in another. I double tap, press and hold and nothing happens.
Just did this (in gmail app on phone)
open message
tap menu key
tap more
tap select text
in new message:
press and hold in text area
select paste (last selection) or paste from clipboard (multiple selections)
Are you doing this on an Atrix with exchange email?
