godsdragon
I have not figured out how to copy or cut and paste text on my tablet... Any ideas? Thanks!
try double tapping on a word(just as if you were to double click with a mouse), and it should highlight the word with a bar at the top allowing you to cut, copy, paste, etc. You can also long press on a word to select it and bring up the menu bar at the top.
Yep, it should give you two arrows that look like they're pointing up, and they're your selection tool. if you drag the right arrow to the very end of where you want to select, and the left one to the very beginning of your selection, then you can copy/cut/paste the entire selection all at once.
