jonny5449
Hiya I'm gonna tell you how to make a completely unique rom or a port
First you need too know the different android OS's
Ones we can use:
Stock 2.3.7
This does not mean you can port any rom based off 2.3.7
Example: Joyos is 2.3.7 but is based on cm7.2
You may be saying
Ones we can use:
Stock 2.3.7
You may be saying
it gives you a feel, then once you have a booting rom, you work on fixing broken things.
