Root How To Create Themes Easy...sorta
blue2107
Well I thought I should post this to help some who want to create some custom themes.Though I don't know it all.
I do know that Ultimate Online Theme Kitchen ( or UOT Kitchen ) Supports Shabbymod .6
UOT Kitchen. Today's menu
If you scroll down to the bottom. On the supported Rom's list you will see Shabbymod .6, PREVAIL ROM. :eek::D
This online tool can help do all ( or at least most ) of the modding for you.
PLEASE DO NOT FLASH THROUGH RECOVERY
please read the how to and all documentation to help prevent bootloops or bricks.
I am going to try this out and post my results asap.
I would also like to request users to post their results.
All successes or failures. To help the rest of us out who want to customize our phones without bricking them.
Thanks for your time
Well I tried placing the framework-res.apk from the UOT.zip
with the one in the shabbymod .6 rom.
But no dice... failed
See pic for details
So could this work with your stock theme flasher?
And why wouldn't it mount? This has never happened before.
I will try out UOT as soon as I can. I saw a bit of it last night and it looks overwhelming but I'm sure it isn't that hard. I got finals coming up next week then I'm off for about a month till the Fall semester. The bad thing is that I'm gonna spend too much time trying to customize just to get a final product I like and even then I don't know if I would be satisfied with my work. Probably end up fixing and tweaking stuff up till I go nuts.
yes you could use teh stock theme flasher to use this, glad it found other uses :)
Shabbypenguin and the Android Creative Syndicate
are proud to present to you
ShabbyMod
0.9​
Alright lets get to the nitty gritty of it all, this is the thread where all 0.x-1.x versions will be released, as it stands right now this is nothing more then just a glorified stock, but its better then that ;). deodexing the rom allows for easier themeing so i want to see some creative shit start to flow in.. yall dont want me making themes... anyways down to the goods
glad to see people are finally taking an interest :P
