Help How to Customize Dictionary
If you are using Swype (default KB in the SIIX) then start from your home screen and do the following...
1) Settings
2) Language and Keyboard
3) Swype (Swype Settings)
4) Personal Dictionary
You can now add and delete words as required.
Also to note, when you use Swype, when you type a word you get suggestions. If you enter a word or name, for this example a name, like Andr
