How to debug my tablet with computer
  • Start date Start date
A
Android Question
Guest
I want to use USB Debugging but dont know where to find it on my tablet
Hi
You dont say which model or make of tablet, but its probably in something like
menu
settings
developer options - tick the box for usb debugging
Roger
I believe that in Ice Cream Sandwich (Android 4.x) and above, Google sort-of hid this option from us.
If your devices is 4.x, then you simply go into your Settings app -> About phone -> press / touch the Build number row (should be the last item in the display) seven (7) times (you'll start getting toast messages about getting closer to becoming a developer).
When you reach 7 (I believe that's right, it might be 8), the Developer options entry will show up on the prior (main Settings) screen. From the Developer options screen you can check the box next to USB debugging.
I'm a firm believer in checking this option when I first start with a device--it gives you recovery options that are simply not available with it unchecked.
Cheers!
