Help How to delete all D3 contacts at once?
r9ball
Using rooted D3.
I want to delete all my contacts at once.
Going through settings-apps-manage-contacts - clear data didn't work,, still there.
The clear data button in contact storage was greyed out so I couldn't try that one.
And I don't want to reset phone.
Anybody know exactly what folder the contact file is located? I couldn't find any info......grrrr
They are saved in your Google cloud.
You can either delete them via gmail.com or go to change your display settings so the contacts are not shown.
Unfortunately, I'm running ICS so I can't recall what the menus are for Gingerbread.
Head to the market and grab Contact Remover. I think you can erase them all. Then you'll get the Gmail "Too Many Deletes" thing, just hit delete every few minutes 'til it goes away.
