If you're rooted you can do this through the terminal. I believe you have to mount the filesystem first, as follows:
mount -o remount,rw -t yaffs2 /dev/block/mtdblock4 /system
IIRC, then you can delete the apps. Deleting is a bad idea though, in case you ever need to restore them. The best thing to do is rename them by changing the extension. Using .bak is a common practice. You would navigate to the system folder after mounting and do something like this:
mv CorpCal.apk CorpCal.bak
That would change the Corporate Calendar app so it is no longer a valid application. If you ever need to restore it, you can just "mv" backwards so it's an APK again.
If I made a mistake here, please correct me. It's been a while since I used
linux and I'm not an expert on Android terminal commands.
Why?How do you delete something like Car Home or Gallery or Maps especially dont ask why oof your droid i am rooted...thanks
Wait why couldnt i just redownload a .apk file of it???
Just don't delete them. You can't re-download them unless you find them somewhere from a person who manually uploaded the files. They're not on the market.
Trust me, just don't do it. If you ever need them back you're going to have a very, very hard time. They barely take up any space when renamed to .bak files, and it prevents them from running so they're not ever sitting in your RAM or bothering you, but they are still there if you need to restore them.
If you ever try to update to 2.1 or something and you do not have those apps, you could brick your phone.
