Help How to delete multiple contacts at once?
bog3yman
I cant find a way to 'select multiple' contacts at once and delete them.. whats the quickest way to delete 60 odd contacts?
have you tried the "delete" options? you can see "select all" then untick the names you want to save. . .
The easiest way to do this that I can think of would be to use Kies Air. You can view and modify your contacts from there, they have checkboxes beside them so you can select all the ones you want and delete them that way.
