How To Delete Navigation Endpoints ?
hshoe007
Have used the Navigation feature frequently and built up a list of endpoints. Want now to delete some of them but cannot see how. Can anyone give me the magic steps ?
Try the following from the maps ap: menu,more, terms privacy and notices, then web history. After you sign in there's a link on the left for maps, and you can remove specific items.
I clicked on remove everything, but the destinations still remained when I check again.
1. Settings
2. Applications
3. Manage Applications
4. Select "Maps" application. It will show the following
Total xxx MB
Application XXX MB
Data xxxMB if it is other than 0 this is your recent destinations
5. To clear recent destinations, select "clear data" button.
