Go into storage mode, and connect your Vibrant to your PC. Navigate to the SD card and delete. Or, you can get a file manager from the Market and install that. Then navigate to the files you want deleted and delete them.
You can use the Files app. Click on the "sd" folder. You should see the files and folders on the SD card. If the files are in a folder click on it so you see the specific files you want to delete. Touch the Menu button > Delete, then select the file(s) you want to delete and press the Delete button.
