scdsteffes
where is the setting to turn off the open\startup music? the one that plays when i unlock the phone..
cheers
cheers
cheers
I hate the music that plays when you unlock the phone and the home screen opens, also the sound that plays when you update the weather. Any way to change this? If so, where and how do I do it? Thanks in advance for any help.
There is an app called Silent Boot that works well. You have to restart your phone in order for it to work. If you pull the battery and then restart your phone it will not work.
How can you change the sound that is played? I would like to add a custom opening sound.
thats what i was wondering? mine doesn't make a sound during boot up, which is niceAnd you're getting a boot-up tune from an Evo 3D?
